edredpeanut
Apr 11, 2020Follower
Netgear AC1750 Ethernet connection slow
My internet speed is 200mbs when I connect an ethernet cable directly to my modem. but when I connect an ethernet cable through the router it drops to 70mbs. I know the router divides speeds betwee...
Apr 11, 2020Guru - Experienced User
1. What modem are you using?
2. What firmware is on the router?
3. Have you tried swapping cables?
4. How are you testing the speed? make sure its wired speeds. Not over wireless.
