Brennan73
Jul 12, 2019Aspirant
Netgear CM1000 / Nighthawk XR500 Issue
Hi there, I am having an issue with either my CM1000 cable modem or XR500 wireless router. I purchased both of them just yesterday. I play Overwatch and noticed two times during a two hour duration t...
Jul 12, 2019Guru - Experienced User
Try a factory reset on the XR router and setup from scratch. I presume the FW was updated upon initial setup and may need a reset.
Netduma-Fraser
Jul 13, 2019NetDuma Partner
When you lost connection was it just on the game or was it on other devices as well? Did it require a reboot to get the connection back or did it re-establish itself? Are you using the Geo-Filter for Overwatch?
- Brennan73Jul 16, 2019Aspirant
I'm not sure if I lost connection to other devices. It's so quick that I lag in game and then it re-establishes connection on its own so I don't have time to look at other devices. And yes, I am using Geo-Filter on Overwatch.
I am trying to read through the system logs when I disconnect and the only correlation I can see is when the router has a log mentioning the router is stale. You can see the log I am referring to in my attached image. Does that log mean anything?Also, should the router be saying DHCP new event and DHCP lease change as often as it is? It's very often.
Thank you!
- Netduma-FraserJul 16, 2019NetDuma PartnerThe log is fine, I generally wouldn't recommend looking at the log as the language is verbose as it is meant for developers so can seem as though there is a cause for concern when there isn't. Have you experienced it again since your post? If you disable the Geo-Filter/set to spectating do you see the issue?
- Brennan73Jul 19, 2019Aspirant
Ok, thank you for the information. I actually haven't experienced the issue the last couple of days. I only had the issue the first two nights of using them. Maybe it takes a bit for Comcast, the modem, and router to sync everything? I'm not sure, but glad I haven't had the issue lately.
