PoPeYe-1990
Jun 02, 2020Aspirant
Netgear gaming
hi, Can anyone help, i want to look into buying a gaming router. At the moment i use a powerline adapter to get the wired connection into the games room, i still get good speeds but would like to...
- Jun 02, 2020Yes you can still make use of the features by having it connected through the power line adapter. I'd recommend modem > XR500 > power line adapter so the XR has full control.
Netduma-Fraser
Jun 02, 2020NetDuma Partner
Powerline adapters aren't ideal but if you get good speeds then that is fine. It would be best to have all devices connected to the router if possible so that it can control all devices and eliminate lag and buffering. If that wasn't possible you're still able to benefit from the Geo-Filter feature. Take a look at the routers here: https://www.netgear.com/gaming/
- PoPeYe-1990Jun 02, 2020Aspirant
hi,
if i was to plug it into my router would i still get the benfits its not directly plugged into my console/pc?
Basically theres no way i can get my router directly into my gaming consoles without the use of a powerline adapter, so i dont want to buy one and not be able to use its full potential.
also which one would you reccomend with my curent setup?
Thank you
- Netduma-FraserJun 02, 2020NetDuma PartnerYes you can still make use of the features by having it connected through the power line adapter. I'd recommend modem > XR500 > power line adapter so the XR has full control.
hi,
Sorry to be a pain but it would it really make a difference if i didnt put it into the powerline so just doing Modem > router or would putting it into the powerline help with where the other powerline is situated? i.e upstairs in another room if that makes sense :/
thank you
