lg-10
Aug 03, 2018Aspirant
Netgear Genie Remote access Registration failed - Never got an email- Can my account be reset
To setup the Remote access, I was trying to register the netgear router using Netgear Genie, but the registration never send an email activation email, for the registration to be completed. I hav...
Netduma-Fraser
Aug 03, 2018NetDuma Partner
You should just be able to go to http://my.netgear.com/ then either login or create a new account. Then click register a product, input your serial number and then it should be registered.
