Lefty_Insider
Mar 25, 2023Tutor
Netgear network speeds
So I have a home network with a mix of Win7 (Pro and Ultimate) and Win10 (Pro and LTSB) machines, desktops, towers, NUC and SFF laptops and tablets. Both wired and wireless. The Netgear Nighthawk XR...
Lefty_Insider
Mar 25, 2023Tutor
Thanks for your response.
Let me now add some new complexity, to perhaps bring some clarity.
I put a Samsung tablet next to the NUC.
The NUC with an Intel Ethernet Connection I218-V got 768Mbps
With the Samsung tablet with the factory dock Realtek PCIe GBE Family Controller I got 319Mbps
Switched the router switch ports, no effect on either
I did not yet switch the Cat7 cables between them.
Switched to a USB to a Ethernet adapter on the tablet and no effect
QOS and VPN are OFF in the router, running newest firmware which is older than I would like.
Router MTU is set to the Max (default) on the router at 1500
Am going to try a SuperSpeed Express Card in the slower laptop to see what that brings. Low expectations here.
Each of these three machines get an ipconfig/release and renew daily via a utility I have. It's an OpSec thing.
Do I need to somehow rebuild TCP/IP on the slow machines? netsh int ip rese?
Lefty_Insider
Mar 25, 2023Tutor
PS. I envy your fiber.
