sdwqxvpkkdgbulh
Apr 28, 2024Aspirant
netgear Night hawk router
So I just have a simple question for you guys with out physical damangeing the router is there a way to disable the physical switches to broadcast wps and turn on/off wifi. My cat keeps turning off m...
- Apr 29, 2024
Can't disable the buttons.
Maybe tape a small sized used cardboard box over the stop of the buttons so they can't be pressed?
Apr 29, 2024Guru - Experienced User
sdwqxvpkkdgbulh
Apr 29, 2024Aspirant
Yeah thats kind of what i thought thanks for that đ
- FURRYe38Apr 29, 2024Guru - Experienced User
Love cats, they walk on anything. LOL.
