Blondozavr
Sep 09, 2024Aspirant
Netgear Night Hawk Xr1000 OFDMA lag in game
Hi. I have a problem. When I turn on OFDMA my ping in games starts to increase. I play on Playstation 5 connected via 5ghz wifi. Geo-Filter - off QOS - off Internet Connection - 935/935 Channel ...
Netduma-Fraser
Sep 10, 2024NetDuma Partner
That may or may not be a cause, could be incidental but you've disabled the two features that would help you keep your ping low so I'd suggest using them and see if you get the same issue.
- BlondozavrSep 10, 2024Aspirant
Hi.
Just turned it on:
- Geofilter
- QOS
The console does not connect to the network.
As soon as I turn OFDMA off everything works fine.
- Netduma-FraserSep 10, 2024NetDuma PartnerAre you adjusting the option while the console/game is on? If so reboot the console then check.
- BlondozavrSep 10, 2024AspirantDid not help
