Blondozavr
Sep 09, 2024Aspirant
Netgear Night Hawk Xr1000 OFDMA lag in game
Hi. I have a problem. When I turn on OFDMA my ping in games starts to increase. I play on Playstation 5 connected via 5ghz wifi. Geo-Filter - off QOS - off Internet Connection - 935/935 Channel ...
Netduma-Fraser
Sep 10, 2024NetDuma Partner
That may or may not be a cause, could be incidental but you've disabled the two features that would help you keep your ping low so I'd suggest using them and see if you get the same issue.
Blondozavr
Sep 10, 2024Aspirant
Hi.
Just turned it on:
- Geofilter
- QOS
The console does not connect to the network.
As soon as I turn OFDMA off everything works fine.
- Netduma-FraserSep 10, 2024NetDuma PartnerAre you adjusting the option while the console/game is on? If so reboot the console then check.
- BlondozavrSep 10, 2024AspirantDid not help
- Netduma-FraserSep 10, 2024NetDuma PartnerYou may need to forget the WiFi on the console then reconnect again by retyping in the password after toggling the option
