Blondozavr
Sep 09, 2024Aspirant
Netgear Night Hawk Xr1000 OFDMA lag in game
Hi. I have a problem. When I turn on OFDMA my ping in games starts to increase. I play on Playstation 5 connected via 5ghz wifi. Geo-Filter - off QOS - off Internet Connection - 935/935 Channel ...
Blondozavr
Sep 10, 2024Aspirant
Hi.
Just turned it on:
- Geofilter
- QOS
The console does not connect to the network.
As soon as I turn OFDMA off everything works fine.
Netduma-Fraser
Sep 10, 2024NetDuma Partner
Are you adjusting the option while the console/game is on? If so reboot the console then check.
- BlondozavrSep 10, 2024AspirantDid not help
- Netduma-FraserSep 10, 2024NetDuma PartnerYou may need to forget the WiFi on the console then reconnect again by retyping in the password after toggling the option
I tried this, but it didn't help
