Vger2
Apr 12, 2020Aspirant
Netgear Night Hawk XR700 wired connection speed issues
Hello everyone. Just purchased the new Netgear Nigh Hawk XR700 Gaming router and am using with with my Xfinity Internet service on 200 Mbps connection and a Motorola MB8600 Modem. I'm using the lat...
Apr 12, 2020Guru - Experienced User
1. is the desktop ethernet gigabit? and have you checked in its device manager to ensure its running gigabit?
2. have you checked the cables? a bad cable can drop you from gigabit to 10/100mbps.
3. do you have another hardwired device you can test the speeds with to ensure it isn't a device specific issue?
Vger2
Thanks for responding. Yes, I have a gigabit ethernet card on desktop. I checked and it is running at gigabit connection speed. Also, I've and changed and tried different ethernet cables.
What I did find out and I'd had this issue before, I'm running Trend Micro Internet Security program. If I turn it off, my speeds jump up to 130 Mpbs + download speeds on test. Seems Trend Micro inteferes someway with download speeds when it running. I haven't had any luck getting Trend Micro to address this issue previously.
So now that I've at least gotten my download speeds up, are there any specific settings I need to look at for wired connections on this router? I have set my default providers IPV4 & IPV6 DNS to Google DNS servers which seemed to have helped a bit. Any other suggestions would be appreciated.
Thanks
- plemansApr 12, 2020Guru - Experienced User
Duma OS has a guide to maximize your speed for your router. I'd recommend looking through it as its quite helpful
- Netduma-FraserApr 14, 2020NetDuma PartnerThere aren't any specific settings for wired connections. Are other devices receiving full speeds through ethernet? The guide above is good to follow to ensure you're not throttling that device.
