gfhartzell
Aug 06, 2019Star
Netgear Nightawk XR700 Plex Server Update required
My Netgear Nightawk XR700 requires an update to Plex Server version 1.16.1 or newer. Currently Stuck on Version 1.14.1.5488. When will there be an update?
- Oct 31, 2019
Actually there was an update today, seems to contain a Plex update too:
https://kb.netgear.com/000061373/XR700-Firmware-Version-1-0-1-20
Netduma-Fraser
Aug 06, 2019NetDuma Partner
I'll ask the Netgear team to see when this is planned and get back to you.
gfhartzell
Aug 14, 2019Star
Any word yet? it apears the did the X10 recenty.
- Netduma-FraserAug 14, 2019NetDuma PartnerI'll check in with the team and get back to you.
- gfhartzellAug 23, 2019Star
Just checking in
Well its been 2 months now without being able to use Live TV without the Required update to the xr700 plex server and no response from netgear.
This is very frustrating. Is it actually part of a firmware update?
Thank you
Gary
- Netduma-FraserAug 24, 2019NetDuma PartnerI've asked my colleague who has asked Netgear to post here directly when they have an idea. I believe when you disable Plex then enable and apply it redownloads Plex so may be possible without a firmware update though I can't say 100%. Try this as well if you haven't already as possible its already been updated.
