KAWB
May 27, 2020Follower
Netgear Nighthawk extender with Ethernet input
Hi all, Hoping someone can give me a simple answer. I have installed the RAX20 Nighthawk Router. I need new wifi range extenders. I have Ethernet running into most rooms in the house (it's a ...
May 28, 2020Guru - Experienced User
many of netgears extenders have access point mode. thats basically what you're looking for. Some of the very base models like the ex2700 don't have access point mode but if you search through the extenders on netgears site and pick the one you want, then just check to see if thats an option for it.
Or you can even use a router and run it in access point mode.
