KAWB
May 27, 2020Follower
Netgear Nighthawk extender with Ethernet input
Hi all, Hoping someone can give me a simple answer. I have installed the RAX20 Nighthawk Router. I need new wifi range extenders. I have Ethernet running into most rooms in the house (it's a ...
May 28, 2020Guru - Experienced User
Please post about this over in the RAX forum:
or the WiFi Extender forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Good Luck.
KAWB wrote:Hi all,
I need new wifi range extenders. I have Ethernet running into most rooms in the house (it's a large house)
I'm wondering if there is any extenders with Ethernet input, that I can put around the house that is easily compatible via the app.
I'm not very tech savvy so hoping I worded that ok.
Thanks so much
