joellabelle
Aug 12, 2023Aspirant
NETGEAR Nighthawk Pro Gaming WiFi 6 Router (XR1000)
Hello, I have the following in my home: NETGEAR Nighthawk Pro Gaming WiFi 6 Router (XR1000) and NETGEAR Nighthawk WiFi 6 Mesh Range Extender EAX80. We are having issues with the XBOX and PS5 being p...
Aug 12, 2023Guru - Experienced User
What is the distance between the XR router and EAX80? 30 feet or more is recommended.
For that size of home, the XR wifi should be enough.
Having too much wifi can cause problems: https://youtu.be/UR0viMLISz4]
No. You could try disabling the XR routers wifi radios and setup the MK MESH system in AP Mode:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
- joellabelleAug 12, 2023Aspirant
Hello,
Thank you for your prompt response! More than 30 feet for sure. The Extender is in the common area so the signal should be equally dispersed. If we connect the XBOX via a cable to the extender, that would reduce the burden on the Wi-Fi accordingly? I also feel the equipment we have is more than adequate for our home. Could it be the speed of the internet we have? Two gaming systems, multiple TVs, work computers, and Alexa, at any given time there may be 20 items on the Wi-Fi. I'll have to see what we currently have but any suggestions on what we should be at?
Thanks!
- Netduma-FraserAug 12, 2023NetDuma PartnerHow have you setup QoS and the Geo-Filter exactly?
- FURRYe38Aug 12, 2023Guru - Experienced User
Can ethernet connect the game console to the EAX. Thought would not be preferred for gameing. Ethernet connections are preferred directly to the back of the XR router.
Have you tried with the EAX turned OFF?
