yurarnd
Jan 18, 2019Tutor
Netgear Nighthawk Pro Gaming XR500 what's his nat
Hi
what kind of NAT it hardware or software ?
Netduma_Jack
Jan 21, 2019NetDuma Partner
Is there any particular reason you are asking this?
- yurarndJan 21, 2019Tutor
hardware NAT reduces ping in the game better than software
- FURRYe38Jan 22, 2019Guru - Experienced User
Hard to tell what NG uses. I would presume it would be HW since these routers do support 1Gb ISP speeds and HW NAT cut thru is needed to achieve these speeds.
- yurarndJan 22, 2019Tutor
thank you, but I would like to know for sure, they say that asus ac87 hardware NAT, I'm just used to netgear and do not want to take asus. I don't know what to do now
