yurarnd
Jan 18, 2019Tutor
Netgear Nighthawk Pro Gaming XR500 what's his nat
Hi
what kind of NAT it hardware or software ?
Netduma_Jack
Jan 21, 2019NetDuma Partner
Is there any particular reason you are asking this?
yurarnd
Jan 21, 2019Tutor
hardware NAT reduces ping in the game better than software
- FURRYe38Jan 22, 2019Guru - Experienced User
Hard to tell what NG uses. I would presume it would be HW since these routers do support 1Gb ISP speeds and HW NAT cut thru is needed to achieve these speeds.
- yurarndJan 22, 2019Tutor
thank you, but I would like to know for sure, they say that asus ac87 hardware NAT, I'm just used to netgear and do not want to take asus. I don't know what to do now
You might try asking someone over on smallnetbuilders. I looked over there and they didn't do a full on test and review of the XR500. They usually know weather or not a router is using HW nat or not. I don't know if any one from NG will answer this. You might contact one of the forum moderators to see.
On the other hand, why not try one out. Amazon and other places online have too return polilcies. You can try one out and see if it works to your liking, if not, return it. No hard no foul.
