wolfkinara
Dec 09, 2019Follower
Netgear Nighthawk router
I've got a crap general issue router from my ISP and want to upgrade to the nighthawk. I hear it's leagues better than most routers on the market and was hoping to hear some opinions from gamers wh...
Dec 09, 2019Guru - Experienced User
Most any Mfr external routers are better designed over ISP modem routers. Having a external router allows users for control over the router. It's recommended to use a modem only with external routers. Though you can use modem routers with external routers.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
