nishan97
May 14, 2020Follower
Netgear Nighthawk rx500 can not connect to the internet
I have the netgear nighthawk rx500 gaming routerbut cant connect to the internet, butmy internet provider is cox cable and they gave me a router that has a built on modem, andv when i hook up the two...
Netduma-Fraser
May 14, 2020NetDuma Partner
How have you connected them together? The ethernet cable should go from the Cox modem LAN port to the XR Internet/WAN port. Do you know if you require PPPoE/a login to access the internet properly?
