Samf2194
Jun 25, 2021Aspirant
Netgear Nighthawk XR-1000 issues
Hello, I recently boughty the XR100 Netgear Nighthawk Wifi 6 router it has been only 4 months since I installed it. At first it was working perfectly with no issues. Recently, it started to fail ...
Netduma-Fraser
Jun 25, 2021NetDuma Partner
When the issue occurs are you getting full speeds through ethernet on the XR and direct to the modem?
Samf2194
Jul 30, 2021Aspirant
I do get full speeds through ethernet.
