Samf2194
Jun 25, 2021Aspirant
Netgear Nighthawk XR-1000 issues
Hello, I recently boughty the XR100 Netgear Nighthawk Wifi 6 router it has been only 4 months since I installed it. At first it was working perfectly with no issues. Recently, it started to fail ...
Samf2194
Jul 30, 2021Aspirant
I have and the speeds are good when I reset it, but after it reduces a lot. Like for example I been checking for a few weeks and once I reset i get like 600 download speeds, a few days later drops too 90. And wireless its 200 download speed and drops to 30 in a few days.
Netduma-Fraser
Jul 30, 2021NetDuma Partner
Does there seem to be any pattern to this, for example more devices being added over that time? Devices being closer to the router etc?
- plemansJul 30, 2021Guru - Experienced User
Anything else connected to the cm1150v?
do you have a screen snip of its cable connections page and event logs?
Maybe the signal is deteriorating.
