yugi8264's avatar
yugi8264
Follower
Mar 15, 2020
Netgear nighthawk xr 450 compatable wiith Optimium
I want to know if nighthawk xr450 compatable with optimium and what is the difference between nighthawk xr 450 and Nighthawk AC1900 in terms of connectivity?
1 Reply
  • Yes it works with all ISPs/connections. I couldn't say precisely as I work for Netduma (creators of the software for the XR range) so can only really give you an idea of the features of those routers. May be best to have a look online and compare them.
