Darkatek7
Dec 14, 2022Aspirant
Netgear Nighthawk XR1000 Backup only Creates a 23 KB file instead of a correct Backup
Hello There, I have the following problem. When i backup my DumaOS Settings the "NETGEAR_XR1000.cfg" is only 23 KB big instead of an actual config backup file. When restoring ...
Dec 16, 2022Guru - Experienced User
So I tested my XR1000 out last night, working with it OFF line and just with a wired PC connected.
I'm getting a 25Kb file generated from MS Edge.
I saved off a first config file from prior usage.
Factory reset the router using the ERASE button under Backup.
At the setup wizard where you can select how to setup the router, I chose load config from back up. Selected the file.
Let the router process the file. My settings has the wifi turned OFF and I use 192.168.0.1 for my routers IP and pool.
The router returned normally and was accessible.
I wanted to try this again and made one change with adding some custom DNS instead of Auto Detect, to the Internet section. After the change was applied and router was back to ready, I saved off another backup config to file. Same 25Kb size.
Let the router process the 2nd back up file.
This time I could not get into the routers web page using same log in info.
I noticed that the IP address on my PC was 192.168.1.1 and should have been 192.168.0.1 after the backup was applied.
I cleared the browser cache to be sure that the browser was clear. Still would not log in. I tried default admin and password and didn't work to get in. I had to press the reset button in back for 10 seconds then release to get back to the setup wizard.
I ran out of time and didn't check with the Backup section of the router to see if after a reset and setup from scratch with out letting the setup wizard use the back up file here, use the Backup section under Admin to see if this would show same thing or not. I also didn't try a different browser though default MS Edge should work as I use it normally for other NG routers I have and have used backups on them.
I think there is something going on here with backup files and use of them on the XR1000. Seems that the router isn't processing them correctly maybe.
DarrenM Netduma-Fraser KevinLiT
Netduma-Fraser
Dec 16, 2022NetDuma Partner
Thanks for the detailed testing results, I'll pass it onto the team and we can figure out if its for us or NG.
- FURRYe38Dec 16, 2022Guru - Experienced User
đ
- RumenJun 01, 2023Aspirant
Any resolution on this.
I had created a backup after the first time my router seized and needed factory reset, only to realize the backup was corrupted.
I did re-created my whole MAC address table and exported again, only 25kb file. Tried Chrome and Firefox no luck.
Latest firmware XR1000 1.0.0.68_1.0.54
- Netduma-FraserJun 02, 2023NetDuma PartnerIt is a Netgear feature so not something we have influence over at all, we did pass it onto NG so it'll be on their ticket system but I can't see that so I don't have any updates for it at the moment.
- FURRYe38Jun 02, 2023Guru - Experienced User
I'll pass this along and see if I can poke the hornets nest. đ
