SashaBi5
Sep 06, 2023Tutor
Netgear Nighthawk XR1000 GAMING ROUTER not see Bsttlefield 4
Hello there! On youtube i seen many games setting in Netgear Nighthawk XR1000 GAMING ROUTER and bought it. But after many tests and switch and change setting in router DumaOs not sees Battlefield 4 p...
Netduma-Fraser
Sep 17, 2023NetDuma Partner
If you don't know what GeForce Now is then you don't need to do anything for it in regards to QoS, Games Console will be prioritized automatically.
SashaBi5
Sep 20, 2023Tutor
Frostbite Engine (Battlefield, Battlefront, etc.) NOT WORK on Geo-Filter Map
- Netduma-FraserSep 21, 2023NetDuma PartnerIf you use it as the Games Console option like we mentioned before it will work for you
