GamestopCheats
Feb 14, 2021Follower
Netgear Nighthawk XR300 Ping is horrible
Hi so I recently bought the XR300 and when doing so got a new modem from my ISP and everything connects great to the router but for some reason my ping on my Xbox One S is horrible and I lag out of g...
Netduma-Fraser
Feb 14, 2021NetDuma Partner
I'd first recommend having a look at our optimal settings guides here and if you have any questions after that we would be happy to help.
http://support.netduma.com/en/support/solutions/folders/16000090646
I'd suggest playing over ethernet if you can but if you have to use WiFi then connect to 2.4GHz not 5GHz.
