ricorami
Feb 10, 2021Aspirant
Netgear nighthawk xr500 and Orbi RBR50 Mesh wifi
Hi - Is it possible to connect the Orbi RBR50 mesh wifi system as an access point to the Nighthawk xr500? My current setup is Gateway/Modem--> XR 500 WAN port. XR 500 Lan port---> Orbi RBR50 (ro...
Feb 10, 2021Guru - Experienced User
ricorami wrote:
The orbi is set to AP mode, and the nighthawk has wifi disabled so that the orbi can handle all things wirelessly and the nighthawk and DUMAos can handle the ethernet portion. ---I'd leave the wifi enabled but make sure its on a different channel to prevent interference. then you can put things like IoT devices or other fixes wireless devices on it. Always good to spread out the load.
I have not changed any settings in any of the routers/access points. And I think it is imporant to note that the only change in my modem/gateway has been that I disabled wifi on there as well.----disabling wifi on the modem/gateway doesn't disable its routing functions. This can add latency/create nat issues. What modem/gateway is it? Does it have a passthrough/modem only mode? Only the power cable and an ethernet cable going into the XR500 are connected to it. It is not in bridge mode.
I.
- ricoramiFeb 10, 2021Aspirant
Thanks for the tips.
The gateway is a Hitron CODA-4582. The way i currently have it setup, i did experience some NAT type issues today. The hitron has a option to bridge it, but the option is called "Disable residential gateway function" for whatever reason. That's what is listed as putting it into bridge mode on my ISP's webstie at least.
Regarding the wifi being enabled on the XR. Does it matter which channel? and how would i know which one to choose and which one to not choose?
Thanks again!
