ricorami
Feb 10, 2021Aspirant
Netgear nighthawk xr500 and Orbi RBR50 Mesh wifi
Hi - Is it possible to connect the Orbi RBR50 mesh wifi system as an access point to the Nighthawk xr500? My current setup is Gateway/Modem--> XR 500 WAN port. XR 500 Lan port---> Orbi RBR50 (ro...
ricorami
What settings do you think i could fine tune? If you have any recommendations.
Thanks!
Netduma-Liam
Feb 11, 2021NetDuma Partner
You can use a Wi-Fi analyser to work out which channel to use based on which is the least congested!
Otherwise as long as you resolved the NAT type issues caused by the upstream router, you should be good to go!
