Fairfacts
Apr 08, 2021Aspirant
Netgear Nighthawk XR500 DHCP error
My Nighthawk is unreliable and its annoyong me. I am getting random but increasingly frequent network disconnects for DHCP errors (not assinging new or correct IP addresses when leases expire). My ...
Fairfacts
I also have an older WIFI router connected through the POE switches for my basement (I left off my config) and it DOESNT lose connectivity when the nighthawk does.
Netduma-Fraser
Apr 08, 2021NetDuma Partner
Please upgrade to the 3.0 beta which has a fix included for this specific issue and see if it is resolved: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/td-p/2071196/jump-to/first-unread-message
I would recommend doing a factory reset after upgrading for a fresh installation
- FairfactsApr 08, 2021Aspirant
Trying that. Router has come back - I will watch for issues. Is there a KB article about the problem and what fix addressed it ?
- Netduma-FraserApr 08, 2021NetDuma PartnerNo KB article no, just the change log entry on that post
