Camostealth
May 24, 2020Aspirant
Netgear Nighthawk XR500 GAMING ROUTER - Only Dropping Download
Hello, I recently purchased the XR500 back in December of last year and have had no problems with it whatsoever until lately. I recently upgraded my speed package with my ISP, which subsequently ...
May 26, 2020Guru - Experienced User
Power OFF The ISP modem for 1 minute then back on while leaving the XR router online.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
- Netduma-FraserMay 26, 2020NetDuma PartnerGive some of the devices that you notice the issue on a reserved IP in LAN Settings and see if it continues to be an issue after that please.
