Owlman82
Aug 01, 2021Tutor
Netgear Nighthawk XR500 GAMING ROUTER Ethernet Speeds
So I have Fiber going to a jack that my router is plugged into. I noticed that when I am plugged directly into the Jack itself I am getting my gig speeds, but whenever I am plugged into the Router wi...
- Aug 02, 2021
How do you have QoS set? Test with QOS disabled first using a good quality LAN cable in between the Fiber Jack and the router and router and PC. CAT6 is recommende.
Aug 02, 2021Guru - Experienced User
