Malomz
Jan 20, 2023Tutor
Netgear Nighthawk XR500 GAMING ROUTER settings for IPTV sports streaming
Hello, I need some help pls. Im not a networking expert and dont really understand the technicalities around networking. However, I was having issues with buffering when I'm watching live live fo...
Netduma-Fraser
Jan 21, 2023NetDuma Partner
Could you provide a screenshot of your Superhub interface please? Did you disable modem mode first as you'll need to do that, otherwise some options may not be available.
Malomz
Jan 21, 2023Tutor
Haaa right, no I didnt disable modem mode.
I will do that now and try it again.
Sorry pls, another question, how does using the dmz on the superhub help with the issue and are there any security issues with doing it like this?
- Netduma-FraserJan 21, 2023NetDuma PartnerIn my experience the modem mode on the hub was a little unstable, causing high pings etc, DMZ was more stable. Having it as stable as possible for QoS to then control will be better. It's safe, the XR has its own firewall.
- MalomzJan 21, 2023TutorThanks again. Ok, let me double check..so change my hub back to router mode, paste the XR WAN IP in the DMZ on the hub and leave it like that. I dont change my hub back to Modem mode?
- Netduma-FraserJan 21, 2023NetDuma PartnerYes that's correct
- MalomzJan 21, 2023TutorGreat. Done now. Is there anything else you suggest i do or just monitor for now and see if these changes make any difference?
- Netduma-FraserJan 21, 2023NetDuma PartnerJust monitor that now, set Congestion Control to 70% for download and upload while set to Always and see how you get on
- MalomzJan 21, 2023TutorThank you very much
