Mirzafahad
Sep 28, 2019Initiate
Netgear nighthawk XR500 gaming router
My question: i am about to buy Netgear nighthawk pro gaming router XR500 but i want to know that it will work with playstation pro or not? I am living in middle east. Most of the time i play fortnite...
Netduma-Fraser
Oct 01, 2019NetDuma Partner
As above. Your ping is most likely due to your location. It depends what server the game is putting you on, it may be putting you on the closest one to you but if not the router could force that which would lower the ping. You could also be experiencing local congestion if there is lots of internet usage happening when you're playing a game. The router can also help with that and lower the ping when this happens.
Mirzafahad
Oct 02, 2019Initiate
Thanks guys
- FURRYe38Oct 02, 2019Guru - Experienced User
:smileywink:
