MrReeceNC
Feb 15, 2020Star
Netgear Nighthawk XR500 lan ports turning off/on randomly through the day
So for a while now my router has been doing this thing where the lan ports will disconnect/reconnect at random. It only turns them off for a second but long enough to disconnect me from a video or a...
- Feb 26, 2020
Ok I will get that done this weekend and let you know if the problem persists.
Netduma_Alex
Feb 17, 2020NetDuma Partner
Have you tried setting reserved IPs for the wired devices?
Although that might not help if the problem is specifically to do with the LAN ports.
This must be a bug.
MrReeceNC
Feb 17, 2020Star
I haven't tried that but I didn't know that you could do that. I will look up how to do this and report back as soon as possible.
- MrReeceNCFeb 17, 2020Star
Also I was looking at the logs of my router and it looks like I've been getting ARP attacks today for a while. Not sure if that has anything to do with it but it's got me a little worried and I'm not sure how to block those particular IP addresses. Not sure if this is something that has been going on for a while or not but maybe it's a false alarm.
- Netduma_AlexFeb 18, 2020NetDuma Partner
Reserved IPs can be set from Settings > Setup > LAN Settings. Just make entries for all of the important devices on the list. It's okay to just leave them with the address they've already got.
APP attacks a DoS Attacks are actually quite normal things to see in the log. The way it's worded is overdramatic, it's just standard internet traffic.
- MrReeceNCFeb 18, 2020Star
Ok I've set up the reserved IP's for the devices that are wired. I will report back with the results later this evening (the disconnect usually happens while I'm watching TV and the TV displays a notification saying the lan cable has been unplugged).
