Misskittys357
Feb 07, 2018Guide
Netgear Nighthawk XR500 slow speeds
We recently purchased a XR500 and after setting it up with the aid of he only video currently available on youtube (Thank you Sim) we are now finding that our 2 hardlined devices are seriously not...
Netduma_Jack
Mar 11, 2018NetDuma Partner
Hi Andreas - if you have disabled QoS and you’re still getting low speeds then it’s either an issue with settings or a hardware fault. I recommend you contact Netgear directly using their 24/7 live support. They should be able to fix this for you. You can contact them here:
https://www.netgear.com/support/contact.aspx
Let us know how get on!
Aje
Mar 11, 2018Guide
Thanks for the quick reply. Emailed Netgear support; case #29839254. Will post resolution here.
Regards
- Netduma_JackMar 11, 2018NetDuma PartnerThanks Andreas - hopefully they get it fixed for you asap
- Netduma-FraserMar 12, 2018NetDuma PartnerHi Aje, I know Netgear are helping you now but just thought I'd add in a potential solution. Sometimes when adding a new router the ISP gets funny about it, if you give the XR500 the same MAC address as the previous router you were using that may fix it.
- AjeMar 12, 2018Guide
Thanks for the suggestion but I didn't have a router previously. It's a new appartment with a new internet connection, and I still run my old setup at my old place. :)
Funny enough, after returning with the system off for 24h, I now get full speed. I don't get it...? Did the router self-correct or what? I'll keep pushing the XR500 today with lots of TB of data and see what happends. I'll keep you all updated. This is really interesting!
- Netduma-FraserMar 12, 2018NetDuma PartnerGreat to hear it's been resolved, thanks for the update! The ISP can just get weird when a new router is introduced, it can sometimes take a few days before the speeds are restored. I'm not sure why this is, the MAC address trick will solve it if that's an option.
