Misskittys357
Feb 07, 2018Guide
Netgear Nighthawk XR500 slow speeds
We recently purchased a XR500 and after setting it up with the aid of he only video currently available on youtube (Thank you Sim) we are now finding that our 2 hardlined devices are seriously not...
Netduma-Fraser
Mar 14, 2018NetDuma Partner
Hi Lynx, that likely means that you have higher than you think as a router can not give you higher speeds that your ISP provides. So if you set it to 356 down and 24 up then at 100% on Anti-Bufferbloat you should also achieve that speed.
LynxZ
Mar 14, 2018Aspirant
Thank you, I tried that but my speeds are still slower for some reason. I get the maximum speed by increasing it past that 356 down and 24 up. It is strange. And this is hardwired in from my ISP router to XR500 to S8000 (uplink and port #1 set to gaming preset) and then to my PC. If I go straight from my ISP router to my PC I get 356 down and 24 up.
- Netduma-FraserMar 14, 2018NetDuma PartnerIf you go straight from XR500 to PC bypassing the S8000 do you get the expected speeds then?
- LynxZMar 14, 2018Aspirant
When I take the xr500 out of the mix, I get 356 Down and 24 Up. If I take the S8000 out, and go straight from ISP router to XR500 to PC the speeds are reduced. The XR500 for some reason is not calibrated correctly. If I input 356 and 24 my speeds are reduced. But this is just my experience. I don't know if anybody else is experiencing this. I just wanted people to be aware that this is happening. I don't know if my unit is faulty, It seems to work perfect now I have everything set up. Just an observation.
- Netduma-FraserMar 14, 2018NetDuma PartnerThanks for letting us know Lynx we'll have a look trying to reproduce it. Glad everything is working perfectly! Do continue to keep an eye on it and let us know if you have any issues!
