Misskittys357
Feb 07, 2018Guide
Netgear Nighthawk XR500 slow speeds
We recently purchased a XR500 and after setting it up with the aid of he only video currently available on youtube (Thank you Sim) we are now finding that our 2 hardlined devices are seriously not...
DMadsen
May 24, 2018Tutor
I wanted to chime in on this. I'm having the same issue with my PS4 and PC. I replaced my old Netgear modem and one of the older Nighthawks with a CM700 modem and an XR500 router.
I'm using Comcast Xfinity with 250mbps down and I'm getting no where near that on my PS4. I've tried with and without anti buffer bloat and I'm averaging 50-80 Mbps on my PS4 hard wired, I get the same speeds on my laptop on wifi. If I'm connected to the modem directly I end up getting 297 Mbps. My phone is the only device connected to my router that's getting the proper speeds, on wifi I'm getting 270-290 Mbps.
I've tried speed tests through Google, Ookla, and Xfinity and they all get the same. I got this router specifically for gaming and love the DumaOs options but these download speeds are a 5th of what I'm paying for. I don't want to return it if I don't have to.
1yonger
Jul 10, 2018Aspirant
The XR500 router tested the correct speed during the initial setup. For whatever bizarre reason the downgraded speeds were setup in the QoS menu under Anti-Bufferbloat. Click on the three horizontal lines left of the wording and manually enter your speeds.
For Comcast, I am getting 300/20mbps (Ethernet only for my gaming PC) for the 250mbps tier plan. This will correct the "slow" speeds. You can do an Xfinity Speed Test under your Comcast account or Fast.com to verify speed. It will be close to the 250mbps or higher.
- AjeJul 10, 2018Guide
Hello again,
After months of troubleshooting without any success I threw out my XR500 and reverted back to my old R7000.
Stability is back.
Speed is back.
And security is back.
Recommended solution.
- Netduma-FraserJul 10, 2018NetDuma PartnerIf you do not come back to us and let us know you're still having a problem, then we're unable to help you resolve the issue.
Judging by other this and other forums, and the poor software in the XR500 I say I made the right call. This product probably shouldn't have been released. Feels like it's still in Beta. Really badly optimized OS.
Either way, I'm using other Netgear products and they are working just great.
- gwager08Jan 02, 2019AspirantI will be doing the same. QOS more like POS.
- Netduma-FraserJan 02, 2019NetDuma PartnerI've responded to your post gwager.
