Misskittys357
Feb 07, 2018Guide
Netgear Nighthawk XR500 slow speeds
We recently purchased a XR500 and after setting it up with the aid of he only video currently available on youtube (Thank you Sim) we are now finding that our 2 hardlined devices are seriously not...
Netduma_Jack
Nov 11, 2018NetDuma Partner
Well done for fixing this. And that's definitely a feature we will look to add in the future.
BDubnTx
Dec 04, 2018Aspirant
To piggyback on what he said, I had the same problem. I upgraded my package from 150mbs to 400mbs and no matter what my speed wouldn’t get over 160-170mbs.
Turns out my problem was the router doesn’t accommodate under QoS for faster speeds than original setup conditions automatically.
I had to manually go into the pull down within QoS and change the speed limit from 170 to 500. And now I’m getting 450-460mbs.
This should definitely be looked at, as it’s not something that jumps out at you and for a novice end user, this wouldn’t even be something that they look at.
- Netduma_JackDec 05, 2018NetDuma Partner
Thanks for letting us know. This is on our roadmap to add for sure. Glad you solved your problem too.
