Misskittys357
Feb 07, 2018Guide
Netgear Nighthawk XR500 slow speeds
We recently purchased a XR500 and after setting it up with the aid of he only video currently available on youtube (Thank you Sim) we are now finding that our 2 hardlined devices are seriously not...
steggs
Dec 20, 2018Initiate
So i have had this modem for a couple of months now and have had no issues. Recently my speeds have dropped dramaticly and i cant work out why.
When i plug straight into the modem i get my normal speeds, but as soon as the router kicks in everything slows down.
- 1yongerDec 20, 2018Aspirant
The XR500 router tested the correct speed during the initial setup. For whatever bizarre reason the downgraded speeds were setup in the QoS menu under Anti-Bufferbloat. Click on the three horizontal lines left of the wording and manually enter your speeds. Using Comcast Gigabit; so I set download at 1000 and upload at 40. Go into settings Admininstration->reboot. This will correct the "slow" speeds from the router. Do a speed test like Fast.com to verify speed.
- Netduma_JackDec 20, 2018NetDuma Partnersteggs - make sure you set your correct speeds in Anti-Bufferbloat’s options (in QoS). While you’re there, best disable QoS too and then run a speedtest and see if that works.
Also try setting your modem to bridge mode or modem mode if possible.- steggsDec 20, 2018InitiateThanks. It’s seems to have worked itself out. Not sure what happened but I will check those things you mentioned
