Misskittys357
Feb 07, 2018Guide
Netgear Nighthawk XR500 slow speeds
We recently purchased a XR500 and after setting it up with the aid of he only video currently available on youtube (Thank you Sim) we are now finding that our 2 hardlined devices are seriously not...
steggs
Dec 20, 2018Initiate
So i have had this modem for a couple of months now and have had no issues. Recently my speeds have dropped dramaticly and i cant work out why.
When i plug straight into the modem i get my normal speeds, but as soon as the router kicks in everything slows down.
Netduma_Jack
Dec 20, 2018NetDuma Partner
steggs - make sure you set your correct speeds in Anti-Bufferbloat’s options (in QoS). While you’re there, best disable QoS too and then run a speedtest and see if that works.
Also try setting your modem to bridge mode or modem mode if possible.
