Misskittys357
Feb 07, 2018Guide
Netgear Nighthawk XR500 slow speeds
We recently purchased a XR500 and after setting it up with the aid of he only video currently available on youtube (Thank you Sim) we are now finding that our 2 hardlined devices are seriously not...
Netduma_Jack
Dec 20, 2018NetDuma Partner
steggs - make sure you set your correct speeds in Anti-Bufferbloat’s options (in QoS). While you’re there, best disable QoS too and then run a speedtest and see if that works.
Also try setting your modem to bridge mode or modem mode if possible.
steggs
Dec 20, 2018Initiate
Thanks. It’s seems to have worked itself out. Not sure what happened but I will check those things you mentioned
