SonzofGod
May 17, 2020Tutor
Netgear Nighthawk XR700 all wi-fi bands intermittently disabling
Anyone else having this issue...no, it was not a cat or kid, the button on the front was not accidentally hit. I have the router mounted vertically on a wall 6' off the floor... ALL bands, 2.4 GH...
Netduma-Fraser
May 17, 2020NetDuma Partner
Does it reset successfully by doing it through the interface? Try that first then set it up, then in Settings > Advanced Settings disable the WiFi radios, apply, reboot then go back, enable, apply, reboot and see if the issue is resolved.
- SonzofGodMay 17, 2020Tutor
Ok, I reset to factory within the Backup Settings page, clicked on Erase. It took me through the Setup Wizard. OS version is 1.0.1.20. Had no choice there. It currently says the 2.4 GHz and 5 GHz bands are Enabled. I had to create a new SSID so I guess I'll have to reconnect to try and reconnect each device.... I'll post back here and let you know.
- Netduma-FraserMay 17, 2020NetDuma PartnerI'd recommend updating to this firmware as well as it should be more stable: https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix
Wow, this router is a pile. I don't see how something can work fine for a year and then just stop.
I downloaded the Hot Fix but it didn't hold. It still shows version V1.0.1.20. I unzipped the file and uploaded it in Firmware Update.
Even when resetting to factory settings is still doesn't work. Won't broadcast the SSID, can't connect to it. The GHz lights just light up then go dark, repeat.
