hal90027
Aug 09, 2020Aspirant
Netgear nighthawk xrm570 - Settings not applying
So my netgear router does not seem to apply any of the settings that i set up via the management software. I have one device on my network that i have set as blocked, but keeps appearing on my ne...
Netduma-Fraser
Aug 09, 2020NetDuma Partner
How have you blocked the device? If you don't disable share excess then they can still grab any bandwidth that isn't being used? Are you using Anti-Bufferbloat as that will allow all devices to use the internet without impacting each other.
- hal90027Aug 09, 2020Aspirant
I blocked the device by going into device manager and pressing block on the device, it even shows up black on this device list but still grabbing network traffic.
I do have anti blufferbloat on as well.- Netduma-FraserAug 09, 2020NetDuma PartnerIs the one that is blocked connected to the extender? For Anti-Bufferbloat use 'Always' and then 70% for both download and upload, does that help at all?
I'll try that, i just have a seemless network, so although there is an extender, everything shows as connecting to same network
