JeffHart24
Aug 31, 2020Aspirant
Netgear Nighthawk
Hello, My XR500 is dropping the internet signal at least 4-5 times a day. I am hard wired, not on wifi. Literally I will be surfing the net, and the signal drops and the router sits for at l...
Netduma-Fraser
Aug 31, 2020NetDuma Partner
I would recommend you reinstall the firmware using TFTP so it installs bypassing the boot process and any issues there and then do a factory reset so you have the freshest install possible. https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
JeffHart24
Sep 01, 2020Aspirant
I followed those steps and I keep getting an error when I am in step 4 at the cd desktop prompt.
It says "the system cannot find the path specified"
And, would it not just be easier to install a much older version of the firmware as my router did not do this for at least a year until your recent updates?
Quite frustrating because I see this has been happening to others as well.
- Netduma-FraserSep 01, 2020NetDuma PartnerType DIR and press enter, that will tell you where you are at the moment, then type cd followed by a directory name and do that until you get to the desktop.
Yes you could use an old version if you wish to.
