GLO
Jul 28, 2019Tutor
Netgear password reset & still won’t login!
Hi, Is there a problem with Netgear login? I reset my password and naturally can’t use the previous password, but even after creating a new one I still can’t get in! Help please!!!
GLO
Jul 28, 2019Tutor
Thanks for your reply.
When I’m connected to my home network, I launch the Nighthawk app I then want to enable Remote Access which then pushes me to the Netgear Account Login page but regardless of password reset it still errors out.
michaelkenward
Jul 28, 2019Guru - Experienced User
That is mynetgear.
Have you set up an account there?
It does not use the same password as your router's GUI.
GLO wrote:
....it still errors out.
What does "errors out" mean? Times out? Rejects password? Something else?
