z-ej
Jul 14, 2020Tutor
Netgear R7000 on Xbox problem
Alright so I’ve searched the forum and haven’t found my specific problem yet. I have my Xbox One X directly connected to the router so it’s not a WiFi issue. My internet provider goes above 500Mbps b...
Jul 14, 2020Guru - Experienced User
What modem are you using?
What firmware is it on? The agreed upon stable version for the R7000 is 1.0.9.42
Qos isn't recommended at speeds >250mbps. just an fyi.
- z-ejJul 14, 2020Tutor
The modem I have is from Spectrum E31N2V1
Firmware for the router is 1.0.9.88_10.2.88
