pbudreski
Jul 01, 2024Tutor
NetGear Router - Device Manager - Un Named Device
Hello I spent sometime with the Device Manager identifying known devices on the NetGear XR 1000. Subsequent to the preparation of an accurate list that reflects what devices on site, an un named ...
- Jul 01, 2024
do you use any apple or android devices that are using private mac/ip address? If so, they can show up unknown
Netduma-Fraser
Jul 01, 2024NetDuma Partner
The above is a very good point, that could be it. Otherwise if you copy the MAC address then google MAC lookup vendor you can enter the MAC address and it will tell you the manufacturer and you might be able to work it out that way.
