Mr_Smith
Sep 03, 2025Aspirant
NetGear Router | WAN / LAN IP Conflict issue
I recently had an issue on my XR1000 where I was not able to apply IP address reservation in the LAN setup page, due to the router reporting back that the LAN IP range is in conflict with the WAN IP....
Mr_Smith
The issue is not being able to set an internal IP as DNS server, the issue is when an internal IP is used in the DNS servers and then you try to apply config changes in the LAN setup page, it then gives an error saying that there's a WAN / LAN IP conflict.
