Mr_Smith
Sep 03, 2025Aspirant
NetGear Router | WAN / LAN IP Conflict issue
I recently had an issue on my XR1000 where I was not able to apply IP address reservation in the LAN setup page, due to the router reporting back that the LAN IP range is in conflict with the WAN IP....
Mr_Smith
The firmware is XR1000 1.0.0.74_1.0.63.
The issue is resolved when I populate the DNS server fields with external (non-LAN) IP addresses. The issue only exists when I have LAN IP in the DNS server, and then try to apply config changes in the LAN setup page.
Sep 03, 2025Guru - Experienced User
Possible for the XR series, requires external DNS addresses and not something supported if a LAN side address is used. This is a gaming router so focus maybe pointed at connections and getting gaming performances between WAN and LAN and using this in a standard connection path way. Having a internal DNS service or device may not be what was intended or may inhibit correct operation of the gaming system and FW. These gaming routers are fairly complex in what there features are and do.
Something to try, set the routers default DHCP IP address range to .100 to .200. Then set a static IP address on your DNS service device to something that is not with in the new DHCP IP address range. After thats configured, then try to apply the static IP address given on the DNS service device and set it in the routers DNS address menu. What do you see then?
I'll check this out with my XR as well and see. Most of the time, i've only used external DNS addressing and nothing from the LAN side.
