Mr_Smith
Sep 03, 2025Aspirant
NetGear Router | WAN / LAN IP Conflict issue
I recently had an issue on my XR1000 where I was not able to apply IP address reservation in the LAN setup page, due to the router reporting back that the LAN IP range is in conflict with the WAN IP....
Sep 07, 2025Guru - Experienced User
So if you set up all IP address reservations first and apply, then set the local LAN side DNS static IP address to be enabled and apply, does the system work as expected?
