Inwinsible
Apr 10, 2020Follower
Netgear router WNR612v3
My Netgear router WNR612v3 not allowing me to change my WIFI password
1 Reply
maybe more info can help us?
What's actually happening? Are you able to log into it? is it erroring out? are you unable to connect to wifi?
We can't help with minimal info.
firmware on it?
modem its connected to?
It might also be time to check into an upgrade. The wnr612v3 was fairly subpar when it was released in 2012 with only 2 ethernet ports, n150 wireless, and 10/100mbps ports. Unless you're running fairly slow dsl, an upgrade could make a significant difference in performance.
