murphymj68
Jul 11, 2020Star
Netgear WAN port issues (Nighthawk and ORBI)
My Nighthawk XR500 fails to connect via its WAN port to my Huawei ONT. I have exactly the same problem with The Netgear Orbi router (model RBR50v2)) that I own. My older TPlink (AC750) and ASUS (RT-A...
- Jul 21, 2020
Victory has been declared!!! :-)
I installed the unmanaged switch and hey-presto the Netgear Routers now establish connections with the Huawei ONT. Many thanks Netduma-Fraser for the recommendation. Months of frustration and unnecessary expenditure wasted on a problem that was solved by a $50 switch - sigh. Hopefully others in this community suffering similar issues will benefit from this post.
As an aside, I tried the other recommendation - factory reset the router while it is connected to the ONT. Unfortunately, this did not work.
Thanks again for your help. It is much appreciated.
schumaku
Jul 18, 2020Guru - Experienced User
Have a small non-managed GbE switch at hand? Connect it in between the ONT and the Netgear router.
There must be something uncommon happening with the establishment of the Ethernet link between the ONT and the router WAN/Internet port - must be a rare interoperability issue.
Vaguely remember having read similar posts in the community or the net.
murphymj68
Jul 22, 2020Star
Thanks for the recommendation. I see that I was hasty in my earlier reply and did not give you credit where credit was due. Thanks again for your input. It's great to finally have a solution to this problem.
- schumakuJul 22, 2020Guru - Experienced User
murphymj68 wrote:Thanks for the recommendation. I see that I was hasty in my earlier reply and did not give you credit where credit was due. Thanks again for your input.
Glad to help! :robothappy: :cathappy: :manhappy:
